Need Turbo lines for my CA
SpdElemts
Hey guys, Just picked up a Ca motor set and i am missing the turbo oil and coolant hard lines. Does anybody know where i can get new turbo lines? Also i will be running a t25 from a sr20. If anyone could give me info on what lines i could use that would be great. Can i just use sr20 lines for my ca18?
Thanks, Jeff
Modified by SpdElemts at 5:41 PM 8/15/2006
Modified by SpdElemts at 6:24 PM 8/15/2006
themadscientist
what do you mean "hard lines"? Are you talking about the intercooler piping, the oil lines? Please clarify.
SpdElemts
Oh i need the oil and coolant lines for the turbo
themadscientist
The S13 SR20 turbos oil and water lines will connect up to the turbo but the engine ends are almost certainly different.
Secret squirrel
Car: 1990 240sx w/ ca18det
just get the taka lines...it will make life 200 times easier. ca hardlines and sr turbo are bishez
SS
SpdElemts
so if i get the taka lines that were ment for the sr20 it should work for the ca18 correct?
Secret squirrel
yea im pretty sure...i have taka lines but havnt put them on yet...ill go check it out tommarow just to be sure.
SS
float_6969
They will work, but you'll have to get an adapter to connect the hardline to the stock oil pressure feed elbow on the side of the block. They aren't the same size on the CA as they are on the SR. Not a big deal. I found one at the parts store.
dvd
float_6969 wrote:They will work, but you'll have to get an adapter to connect the hardline to the stock oil pressure feed elbow on the side of the block. They aren't the same size on the CA as they are on the SR. Not a big deal. I found one at the parts store.
what kind of adapter?
CaEric
Car: 91 Sr Pwred Coupe
Hey float what kindaadaptor did u get ? what store ?
teddy
Car: Saab Turbo and MR2
Should be a M12x1.0 male end -> M12x1.25 female iirc. Unless you just want to replace the taka -an -> metric adapter.
RalliartRsX
I think it has to be an adapter from a 1.25 thread type to a 1.0 thread type as thats whats on the CA block for the oil hardline.
I ordered some lines from Taka (I 100 % recommend just on impeccable customer service. The guy's great!!). I will let you know when they get here what fitting it should be, but I am pretty sure the CA blocks thread type is 1.0 and the SR is 1.25
Other than that, the lines bolt right up!! Also, changing the rear coolant hardline might be a bit of a hassle because the coolant hardline sits between the back of the block and the firewall (right above the transmission). I did take a prelimanary go at it to see how hard it was to remove, and it seems it might be a tad easier as compared to the SRs (aka, I can get a hand and a screwdriver in there to pry and wiggle it off )
Let us know what else you need
RalliartRsX
damn, beat me to it teddy
teddy
Does anyone know if the taka oil feed line is -3 or -4an?
skoolymarm
Car: '89 240sx coupe & 91 240sx fastback
teddy wrote:Does anyone know if the taka oil feed line is -3 or -4an?
good question teddy, i was just about to ask it myself. i need to know becausei may have an opportunity to build my own.
