94q45t »
https://forums.nicoclub.com/94q45t-u30696.html
Fri Jan 03, 2014 9:14 am
Hello, everyone, and Happy New Year. Just wanted to provide some feedback.
The answer to the problem was "all of the above". There was no single cause of the vibration. It seems the car, which has never had any major work, has aged as a system. When we bothered a major chunk, the transmission, it messed up the karma. As it turned out, the Harmonic balancer was bad, but also the idler pulleys. Together they were chewing up one of the belts. Next, the trans mount made a HUGE difference. Though we had replaced the original (which showed no signs of fatigue) we did so with a used one (also showing no signs). On a lark, we replaced that with a new one - Shazam! Still need to dive under the plenum for other reasons, but it's a smooth running car at the moment. One other thing: we created a bit of a revolt at local dealers since all of them had defective harmonic balancers. Nissan took note and sped one to me without the threatened weeks delay.
Again, thank you all for your help.
