need transmission help
Supernick37
Car: 1990 Infiniti Q45, 1990 Honda Accord 2.2L Turbo
90 Q, 190k on the motor/trannyi have 0 history on the flush status
but here is the deal, the transmission will not go into (D) drive from a dead stop but will when im moving about like 10 mph. It will go into 1,2,3 fine and drive but when i apply more then 1/4 throttle it just slips, then i let off the gas and it catches again.
ive been told that its the turbine sensor which i have just bought, but i have also been told that its the transmission shift solenoids (upper and lower)
ideas??
Supernick37
pic of car... with the wheels i play on tossing on it... sorry about the quality
camera phones are gay
Q45tech
190k is very old life for a 1990 transmission. Most got replaced under warranty...............even 140k is good life if you didn't maintain them frequently with fluid exchanges.
Your FSM details pressure tests and diagnostic which can help pin point the worn components.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Tech is probably right, however you could try adding your external cooler and doing a flush and see if that helps. Youll need the cooler for the new trans and the $100 spent on a flush might be worth it to get another few months out of the trans.
