towncarblue »
https://forums.nicoclub.com/towncarblue-u59849.html
Wed May 09, 2012 6:41 pm
i have a 2002 nissan pathfinder 4x4 se with 125,000 miles .
i need to replace my transmission filter [ got a beck/arney] and fluid.
when i went to autozone i saw atf+4 [ dont know what it is... ] dexron and Mercon .
i have checked the search feature and the recomendations are either nissan matic D or atf. does atf+4 = atf ?
what fluid am i supposed to use?
also... which radiator transmission coolant line am i supposed to disconnect while flushing out the old fluid? driver or passenger side? is there a tool i can buy to completely flush out the old transmission fluid [ i read a post where someone used a tool to drain out the tourque converter] ?
