need transmission fluid info
towncarblue
Car: 2002 Nissan Pathfinder
i have a 2002 nissan pathfinder.
about 4years ago i did a transmission flush with castrol transmax import.
the color is now now very dark/black-reddish. im gonna do another flush in a week or so.
upon some searching i found a new transmax fluid , Castrol 03518 Transmax ATF Green High Mileage Transmission Fluid\\
https://www.amazon.com/gp/product/B00T9 ... Z71CZYB4DM
should i use this fluid in my transmission??
am i better off doing a complete flush or should i just drain and refill { repeat every week for three weeks } ??
AlanAZ
Car: 2003 Infiniti QX4 RWD
I've read on this forum that Valvoline MaxLife™ DEX/MERC ATF (and validated by an ex-Nissan mechanic on another forum, who writes that it's the closest to the Nissan ATF) works well. I changed mine to it (120K mls, original fluid from what I can tell from it's service history, turned brown) 6 mths ago using the drain/fill/flush method so all was replaced (and added a MagneFine filter in the cooler return line), shifts perfectly, fluid is a light red color.
towncarblue
thncx , ill use the valvoline maxlife to flush the transmission
yeldogt
Car: 02 Pathfinder 4X LE (X2)
I just do refresh on mine -- drain the pan through the drain plug. refresh the additive pack. The filter is just screen.
Personally, I never screw around with trans fluid -- the real stuff is on amazon for 10-11 bucks ... Think it takes 4. The last time I did mine I was able to get a case of six for $50.00 on e-bay. did the trans and electric transfer case.
Amazon also has the Nissan coolant for $21.
bmconway76110
Car: 2001 QX4
I second the Max Life suggestion. I just mine and it seems great
