Need to wire engine fuse box
lilnev11
Car: Nissan 240sx se
I just bought an s13 for dirt cheap the only issue is that i have to completly rewire the engine fuse box, i can,t find any diagrams that can tell me which wires go where and there are none that are color coded. If any one knows of any sites that'll have something i can use that'd be great i want to get this thing going again! thanks alot!
Oh and i almost forgot , i drive an 89 s13 with a ka24e, and the battery has been relocated to the back,
Modified by lilnev11 at 5:10 AM 12/14/2009
J14cm7
Car: 95 240sx S14 SR20det
There probably is not going to be a diagram anywhere that jsut maps out your engine bay fuse box. Instead you will have to use the S13 FSM and go through the diagrams and they will have the pin outs and wire colors in that. It will take a little while but it will have everywire in there. Also you will learn alot about your cars wiring at the same time.
lilnev11
Yeahh, it's a mess! hah but this stuff takes patience
Thanks alot
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
painless makes a fuse box kit with color coded wires..has instructions and a sweet box you can relocate to fit anywhere...you can find em at jegs or summit or order one from your local pro shop..this will make your task fast and a whole lot easyer...they are a universal color code so you would only need to match up with the fsm on the harness..good luck..wireing sucks..i hate it personally.
