Silvia14b_TX wrote:what about those "Tornados" that go in your intake? Do they work? I just bought one.
Also i got a cheap resister that is supposed to help mpg.
no...
simple way of conserving gas are
pump in the morning wen temps are cooler, gas expands with heat, so even if it reads 10 gallons thru the pump, it might be a bit less...with gas prices these day u want what u payed for,
dont pump when there refilling tanks, sediment rises and itll get in ur tank...nuff said
dont get all fast and furious...why be stupid?
run A/C minimal, if at all...just remove the belt in seasons u dont need it...less drag
remove clutch and replace with electric fan...less drag better mileage
dont be a led foot in street and floor it...the constant high and low speeds kills mpg
stay at a pace in the freeway...stayin at 60-65 constant actually saves gas instaed of constantly flooring it to get acar ahead..
proper oil changes
for lower mile engines or rebuilt engine...seafoam isnt a bad idea
