Need to replace rear struts. Doing it myself. Any tips?
RamonetB
Car: 1990 Black 240SX
Hello once again, everyone.
My 1990 240sx (a current drivable project car) is in need of new rear struts. I've decided to undertake this task myself. As I understand, it's fairly easy (spring compressor aside) just time consuming.
Can anyone offer me any tips on things to be aware of so I do it right the first time?
Thanks all you wonderful people you!
-kirk
Silvia007
Car: 93 Nissan 240SX SE Fastback
If you're reusing your springs, the only hard part is the spring compression part. Otherwise, it's 3 bolts and the strut comes off.
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
one of my rears is blown but i'm waiting until i can afford coilovers. so yes, for now my car is totally suck. just keep in mind your goals for the car, since it's a project, and don't bother buying a part until you can afford and install the right part.
crackler
Car: ZOMG JDM TYT3
Mark how the top hat is in relation to the bottom bolt hole. I twisted mine just a little and it made it kind of a pita to reinstall. Other than that, a good set of spring compressors and that is it.
ricebike
2002 Quest
2005 Altima
... & a trip to the alignment shop afterwards...
i'd save up to do all 4 corners, then just have it aligned once... or do that Firestone unlimited alignment packages...
95lstegman
actually, i've always done my own alignments. kind of a shadetree method when people see me do it, but i get more accurate toe settings than most laser machines i've had my car on, and i can get other things more accurate as well. i can pretty much get +/- 0.02* on camber and toe. i haven't messed with caster at all yet.
RamonetB
Just got done putting the new struts in. Actually kind of fun! It really gives a sense of pride and accomplishment knowing it's your own handy work that's going into keeping your car running.
Thanks to all who offered tips and "don't forgets." Hopefully, I'll have some pictures up at some point. Not to mention more questions as there is still quite a bit to do.
Thanks again all!
-kirk
RamonetB
I'm always game for picking up a few new tricks. How do you go about it? Or do you already have some posts up describing that?
-kirk
