Hey guys!
I did some searches as was surprised to see that there is very little info on it here.
I need to replace my heater core. There are no leaks, but I know it's partially clogged. I don't get good (or consistent) heat in cold temps. Considering I had to have my radiator also replaced because the PO got it clogged up, and also taking into account I had the core flushed and was told there was a ton of gunk in it... well... I don't want to be cold this winter.
So, I've got a new heater core.
I know I need to remove the dash and drain the coolant. Disconnect the heater core hoses from the engine as well. Stuff like that. BUT, can anyone here give me a better insight on how to perform this operation?
This thread:
zerothread?id=5808 talks about woes in trying to remove it from the driver's side vs the passenger side. Any thoughts or suggestions on this?
I've never done a heater core replacement and have no doubt I can do it. But the more I know the less I have to discover and curse about later.
Help me out, guys.
