ascdesigns »
https://forums.nicoclub.com/ascdesigns-u138661.html
Wed Dec 07, 2011 4:42 pm
Hi all,
As the topics states, I need to install new carrier bushings for the front diff. Mine are shot, causing a vibration, clunking and CV binding if I hit a big enough bump or if I accelerate hard causing the front end to lift. I do have some OME HD (Old Man Emu) springs up front so there's an appx 1.5" lift.
If anyone has replaced just these before, can you help me out here? These are the "arms" or brackets that have bushings on each end (i.e. fore and aft) of the diff carrier, and mount to the diff using 4 bolts (2 top, 2 rear).
Specific questions:
- Do you have to remove the struts to access the four 17mm bolts that hold the carrier to the bushing arm/bracket?
- Do you have to unbolt the CV's from the diff carrier? (I would think not since the CV's can flex upwards quite a bit)
- Lastly, how much do you have to drop the front diff so that bushing arms/brackets came out easily?
Thanks in advance - I appreciate any input that would save me some time getting these darn things replaced!
- Al
