Need to replace all interior and need help!
mullin22
Car: 1994 240sx convertible
I need to replace all interior on a 1994 240sx vert and was wanting to know what is compatible if anything from a coupe or hatchback? Especially the back interior. Any help would be greatly appreciated.
krash
everything from the coupe is compatible except for the door panels and the rear side panels. If you're up to it, you can swap the vert doors with coupe doors and then use the coupe panels, or modify the vert doors to fit the coupe panels. There are a few threads with all the info on how to do this
Good luck
onosqv
Car: '92 240sx Vert
just to elaborate on krash's post: the pillars obviously don't work (a, b, and c); neither will the trunk carpet & panels.
the rear seats from s13's won't really work w/o significant modding.
When shopping for parts, just look @ the picture. Then go outside & look @ your vert. Most parts that are compatible are fairly obvious.
good luck.
KA27DB
i've been reading lots and lots of posts on this forum about converting your doors to coupe doors. But, I was wondering is it possible to modify the coup doors, but still keep the B pillar seat belt holder. Just have the belt exposed where the coupe panels end? make sense?
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
Just look up the conversion. I think they are using back seatbelts from coupes or something. If your that into keeping the inside stock just go get your seats redone at an upholstery shop. Or try to search for a donor car online. I found some place parting a vert out over the net a while back ago. It was some junk yard in California. They are around you just have to look. Or find someone that has pulled out their interior to build a race car.
