Need to replace all exterior lights..
Hayes90
Car: 1999 Pearl White QX4 90k miles
Im in the process of replacing all of my exterior lights... but the problem is. there is no wayyyy im spending close to $600 or more.. is there anything i could possibly do
Modified by Hayes90 at 6:57 PM 1/4/2010
MagicM
Car: 2007 Black/alu trim /black interior M35x 2005 Range Rover HSE 2000 Range Rover p38 4.0SE
600 dollars for what? most of the bulbs are like 4 bucks each, and 50 for the DIP.
Hayes90
not the bulbs. the actualy break lights and headlights.. and fog lights.
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
Hayes90 wrote:not the bulbs. the actualy break lights and headlights.. and fog lights.
So the housings?
Mind if I asked what happened? Some punk kid come by and smash them all in?
Hayes90
when i bought the truck i tinted the tails and now they look like hell. and the fog light housing is all fogged up and scratched up from rocks and dirt coming up from cars infront of me.. and the headlight housing plastics are all broke
fueler
Car: 2 Nissan's
2 BMW's
unfortunately for such a rare car its gonna cost u. its gonna run you around at least 600 to get ALL the lights at a junkyard (headlights 250 a pair, tails 150 a pair, corner lights 50 each, fog lights and turn signals another 50 each)
Pwnin O'Brien
You could always just refinish the lenses. For plastic lenses you just get some wet sandpaper and wet sand the lenses and then polish them with some plastic polish. If you tinted the tails with a spray-tint, such as VHT Niteshades, you can use some lacquer thinner and scrub them clean and then refinish the plastic lens. If the lenses are glass (like the headlamps) you can use a glass polish and polish the imperfections out of the lenses. It wont take any huge chips or cracks out of the lenses, so it doesn't work miracles. After refinishing the lenses, they can look better than new if done properly.
Natedogg1701
Car: 2003 Nissan Pathfinder SE
do you want oem factory or aftermarket? u can get headlamp and corner markercombo for 140-150 shipped. black altezza tail lights for 100 buks at the most,and a fog light set for 50 buks, all off ebay. the headlight/corner marker is ablacked out set, looks a lil diff than factory, not to bad, the altezza tails look way better than factory,my opinion anyway. so wut, 300 about, better than 600 right?
Hayes90
thanks guys, i might try fixing them myself first.. because it would save me a whole lot more
