Need to remove fuse to start, what's going on?
Slipstream
Car: '94 Sonoma, '90 300zx n/a
I had my fuel pump go out about 3 years ago. Well, after I changed it out, my car wouldn't start ('95 240sx SE). I couldn't figure it out for the life of me, until a talk with a Nissan tech from a dealership. He told me that they sometimes have a problem with flooding and what I need to do is remove the fuel pump fuse, try to crank her over and as soon as she starts, plug the fuse back in. It's a pian in the *** to do, but it works. Problem is it will do this once about every 2-3 months. What is causing my car to flood like that? The smeel it gives off almost smells like starter fluid, really ethery.
Also when I have my heater on past the second notch, I can smell fuel vapors coming through the vents, but only ocassionally. Any clue on this?
navysnail
when you remove the fuse, you are allowing the engine to turn over without any fuel going to it, but when it starts the fuse must be replaced to keep it running. use a fuel pressure gauge to see if your system holds pressure when you remove they key to make sure an injector isn't stuck open.
Slipstream
Where do I tee it in? Between the fuel rail and filter? The injectors are pretty old, probably wouldn't be a bad idea to replace them.
struckinc
Car: 93 hatch.stock.well mostly anyway-SOLD
97 kouki-stock
12 sentra sr-wifes new car
97 maxima-wifes car-SOLD
02 maxima se- daily
1936 austin 10/4 lichfield
or possibly a bad fuel pressure regulator
Slipstream
Is that difficult to remove and replace?
Slipstream
Also, could one of those problems be the cause of the fuel vapor smell coming through my air vents?
