Perrenial Badass »
https://forums.nicoclub.com/perrenial-badass-u98460.html
Mon Apr 12, 2010 12:29 am
4 bolts under the defog vents, one on each end near the bottom, and two in the middle behind the radio/AC. The removal of the dash is a 10 minute job. Depending on your luck, the removal of those two defog vents might be a 30 minute job. Get a really short flathead screwdriver to pry out (forward) the metal clips holding the vents in, and then gently pry upwards with a large flathead. Slide it under the lip and gently rotate the larger one while pushing the clip forward until part of it lifts up, then slide down and get the next one. There are 6 or 7 of those f***ers total, try not to break the vents.
And if you have a digital dash, make sure the first thing you do upon reinstallation is plug in the power supply. Before you set the dash in place, if possible.
