need to know what these are for...
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
s13 sr in a s14one of the plugs has a brown wire and a orange/black stripeother is black and blue/white stripe
oneslow240se
Car: 91 240se
that looks like the same thing that was on the bracket along with the ignitor, there were two of those. I'm not sure what they are either my guess is its a evap purge solenoid maybe for emissions ?
bump since i wanna knoe also. like this
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
Whatever the thing is, that has the little nob on it w/ bright green parts, you don't need it. I removed mine, all I know is that it is an emissions thing that hooks up to the AIV deal that everyone removes anyways.
karmakaze
Car: 98 240sx SE
The solenoid is the stock boost solenoid the green thing is your boost pressure sensor for the stock boost gauge. They both usually get tossed out.
I got my hands on the stock boost gauge and need it however. Send me an email if your interested in selling the green thing.
[email protected]
Warped
yeah i'll sell it since i don't need it , shoot me a price shipped to [email protected]
anyclue on the other 2 plugs
karmakaze
Car: 98 240sx SE
are they part of your transmission harness?
Warped
no they aren't they are part of the main harness
Warped
any clue?
karmakaze
Car: 98 240sx SE
Warped wrote:any clue?
nope. but i am going to say that you probably don't need them because they are not located in my harness. (mine was done by wiring specialties)
Warped
i found out what they are for thanks to a fellow az240sx guy
1. orange/ black = Wastegate Valve Control Solenoid Valve.2. purple/ white = Power Steering Oil Pressure Switch. This should be run from the ecu to the white power connector.3. orange/ blue = Air Induction Valve. You cannot use this without modifying the metal tubing.
You can safely remove ALL of these connectors with no ill effects.
