NEED TO KNOW ??
Sleeper415
Car: 240sx
iv got another problem i need to know is that hose that iv high lighted green needs to go connected to that black box.
i say this because i dont have it like that and because iv seen ppl just have a air filter connected to one end of the T it has by the valve cover so i dont know
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
that looks like the coolant line to the turbo..its hard to tell. and that black box is the catch can.
simply follow the line and figure out where it leads. its not that hard.
Hijacker
Car: '92 240sx Convertible
'94 F-150
the line you highlighted green is indeed a coolant line for the turbo. the black catch can is routed onto a fitting on the block directly under it.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
The line you have highlighted is the turbo coolant feed line. DO NOT route that to the black box. The black box is the stock oil catch can, and should be connected to the "T" fitting on the valve cover, and the crankcase breather at the back of the engine below the exhaust manifold.
AmoebAssassin
Damn beat me to it, lol
Hijacker
'94 F-150
i r teh win :D
Sleeper415
Car: 240sx
the thing is i dont know where it goes (the green hose) right know i got it T to my coolint line (the red hose) and i dont know if it need to run to my turbo in any way?????
i need to know where it goes or if the way i got it works????
Hijacker
'94 F-150
there's a hard line coming off the side of your turbo that is routed towards the back of the motor. the hose from the coolant branch (circled in green in your first pic) connects to that hard line.
And from the looks of the first pic, I think you have them routed correctly, but I can't see over the marks you made in Photoshop
EDIT: found a good pic for you. from SCC's swap article.
if you look you can see the hard line leaving the hose and then bending down and towards the turbo.
Sleeper415
Car: 240sx
so its not conectied at all to the black box like i thought and i have that hose Td to the other coolint lines so i think i got it wrong because isnt that little hose (the green one) used to cool my turbo?
Sleeper415
Car: 240sx
i just looked at my car and i dont have any line comeing out of my turbo???
wow hum i need to know if anybody can tell me where its suppost to come out of from the turbo cuz somethings not right.
Hijacker
'94 F-150
the coolant line that we're talking about off the turbo is the one on the back side of the central housing. there should be a hard line that comes to the backside of the motor.
Sleeper415
Car: 240sx
ok i have a hrad line thats coming out of my turbo in the middle i dont know if its connected because i cant see and i can only reach so much in the tight spot hum i think its my oil return line cuz its running to the side of the block right next to were u chech the oild level but then again ther is another hose thats bigger and its in the bottom that i think is my oil return line so i realy am confused?????
Sleeper415
Car: 240sx
ok i got a pritty good pic to ecplain all the crazy sh*t im talking about the hose (orange) in the bottom is i think my oil return line the green hose is????????
Modified by Sleeper415 at 2:32 PM 11/11/2006
Blown240sx
Car: 1996 240sx
If it goes into the top of the turbo its Oil feed. If it goes int he side it coolant return/feed.
deCksy
the orange is oil return
Sleeper415
Car: 240sx
ok im am really just lost????????????????
so i dont have a line from my turbo that goes connected to the lil coolent hose????????
so do i have it right or wrong???? i thought the my turbo suppose to cool down with oil and coolint now i have really no idea is going on?????????
i also have this whole with rigges (orange)almost like if a scrwe goes there or its missing can anybody help me out and let me know ?????
thanx
Sleeper415
Car: 240sx
just puting my self back on top cuz i still need some help
someone is probably going to hate me for it but i just want some of my questions answerd and i really do apreaciate it thanx.
Blown240sx
Car: 1996 240sx
The side ports are coolant feed and return. There is a hard line that runs fromt he back of the motor which you circled in the first pics and runs to the side of the turbo then it feed out the other side back into the block through another hard line. The Oil feed through the top hard line and returns out the bottom hardline.
There is that clear enough?
Sleeper415
Car: 240sx
ok thanx that was super clear the only other question i have is- from the last pic i just put up the thing that i curcled in orange is were my coolint line suppost to go right????
Because i have 2 one on each side with (as u can see) nothing there.
if that is where my coolint line runs to how does it go - is the one in the outside (facing the engine bay) running back to my block and the one thats in the inside (facing the motor) thats were the coolint line coming from the back runs to.
or im i wrong????
Blown240sx
Car: 1996 240sx
Find the FSm and it should have a pic of the turbo line setups?
