Need to know, please!! DOHC head on SOHC block?
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
He guys, i need to ACCURATELY know:
can i use a DOHC engine block on a SOHC motor?? Reason is ive found a DOHC block and i need it for my SOHC. Let me know!!
Thanks,
Jason
comatoseculture
Car: 1990 240SX coupe. Currently running on Megasquirt.
NO.
But this is assuming you really are asking can you use a dohc engine block with a sohc head, rotating assembly so on.
No you cannot.
JNM240
Yes, i am rebuilding my built, high compression SOHC after blowing the head gasket, and i need a new block since i have some wicked pitting in the cylinder walls. So i am asking if the DOHC engine block is basically interchangeable with the SOHC engine block, and if not, what are the differences?
Thanks!
biggie
There are quite a few differences, only a couple people have ever put a DOHC head on a SOHC block, I've never heard of it the other way around and even that took lots of money and machine work.
Just find a SOHC block to go with the SOHC head.
Klits562
Car: white s13 coupe
bore them cyl walls out son!!!!!!!!!!!!
seriously just find a new block they're cheap and usually easy to find
hell if your in so cal i can find you a complete single cam for like $100 it still runs too got pulled out of my friends car he got rear ended
JNM240
I cant bore it out and still reuse my custom made high compression pistons. That is why i need another block. And they arent exactly a dime a dozen in the New Orleans area.
ShimiBoiS13
Car: 1993 240sx Coupe
shoot...jus look online and hav it shipped to u. or go to a shop and ask them if they can order one. gluck
