Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Jun 29, 2007 12:57 pm
Not really because the secondary winding has a diode making resistance measurements tough.
Plus positional differences vs engine plug well and operating temperature of coil.
The usual method is to do a power balance test or monitor exhaust purity to zero in on the weaker coils.
One uses BG44k and resistance measurements to absolve injectors.
It appears that more modern cost constrained coils have a finite time to failure of >70,000 miles ..........................Delphi states their some of their newer pencil coils only last 2,000 running hours....................that's only 100,000 miles.
Yet I know the 90 Q [price no object- very robust design] have lasted more than 10,000 hours on my Q.
Something to keep in mind is the coil is ~~0.5 ohms and draws ~~10 amperes for a few miiliseconds to charge. This is 10X higher current than an injector....................heat creation with no gasoline to coil it.
