diablo70360https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113NEED TO KNOW HOW TO GO ABOUT CHANGING BELTS ON A 350ZMon Aug 27, 2007 2:30 pm
Postby
bone_stock_240 »
https://forums.nicoclub.com/bone-stock-240-u55171.htmlTue Aug 28, 2007 6:18 am
There are 2 options that I would consider in this situation.
1. Look at the factory service manual for instructions
2. Common sense. Look at the pulleys on any given belt. Locate the one that has some sort of tension adjustment mechanism near it. Release the tension and remove said belt. Lather rinse and repeat for all belts.
Postby
turbo6 »
https://forums.nicoclub.com/turbo6-u543.htmlTue Aug 28, 2007 6:19 pm
There are two belts and two tensioners. Loosen the bolt (14mm) in the middle of the tensioner pulley, then turn the tensioner adjustment bolts (12mm) counterclockwise to loosen the belts. Replace belts. Turn adjustment bolts clockwise, and tighten the middle bolts.
