It is the same amount of grease on both passenger and driver sides
Here is a picture I found on-line. Mine is similar (the boot itself is in perfect condition and the oil "leaked" is not fresh. It is all covered with dust):
Last Summer, it was like that on the passenger side only and folks in this forum thought it is the oil that dripped during the oil change (oil filter is just above that area). However, that "sweating" is on both sides now.
I know the boot should have grease in it to protect the join inside, but do you think I need to worry? should I go to the service? probably they will want to change the whole assembly...Is it normal to have little leakage? should I need a better clamp???
