evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Oct 15, 2008 11:48 am
thre rb20 I don't think has as much power potential as the L28ET, I know it won't make as much torque, the L28ET does nto need anythhing done to the bottom end till you are approachign 400 whp, and even then all it needs are forged pistons, the motor has 7 main bearings, I've only ever heard of one car breaking the crank, it was a 14:1 race motor n/a and making 250 whp, otherwise all the power mods that the L29ET needs are the same mods all the rb's need, injectors, ecu, fatty turbo, front mount intercooler
as for your jerky carbs, which carbs do you have? early or alte ? the tops of the carbs rounded edges or squared off? have you adjuste dthe floats? how about the jets? stock needles?
don't get me wrong if you really want an rb thats fine, but it's more than just buying an engine, you'll need the trans, a custome driveshaft, custome oil pan, pickup, motor mounts etc, you can find wrecked 82-83 280zx turbo parts cars and take the full swap for $500 or less, I;'ve bought and parted 3 ut myself and never paid more than $450, everything bolts right in, you hook up about 6 or 8 wires and you have 180chp, turn up the boost and you can get over 200 whp, keep in mind these cars only weight about 2200 lbs, add an intercooler, fatty injectors and megasquirt and you can get to about 300 whp before you need to replace the headgasket and headbolts, then you cna add a fatty turbo and get to around 400 whp befoer the pistons give weay, upgade the pistons and with the right turbo, and headyou can get north of 500 whp, in a 2200 lb car!
