carmo »
https://forums.nicoclub.com/carmo-u91933.html
Mon May 19, 2008 3:30 pm
If you have the means you should pull the motor. Then resealing it is no problem. If i remember correctly there is coolant running through that front cover and if there is enough slop in the timing chain and no guide to run on, you could wear through the cover mixing your oil and coolant. And if you dont catch that fast enough you will need to pull the motor. KA24 is stout enough to handle low boost. Bring the thing up to snuff as far as mileage based maintenance. Seals, gaskets (usually just a tube of Nissan silicone), a lifter or two, maybe valve adjustment, timing chain and components, etc.... all of these things are fairly cheap when doing the work yourself. Plus with the motor out you can clean the engine bay up, maybe flat black it. Clean the motor up. Really prep the thing to look good when the turbo comes. And you can sleep good at night knowing that a loose chain wont skip a tooth under boost and send a valve into your oil pan. DO A COMPRESSION CHECK FIRST! Make sure the motor is worth light maintenance. Good luck
