need to find build up parts
Phixius
Car: S14 w/RB26 and AW11
I'm trying to rebuild/Build a CA for 300-350HP but having troubles finding some pistons to overbore the ca to 1.9, I think its 84mm? Ive found some 83.5mm but thats it. Also looking for strong headgasket to hold 20+ PSI and Top mount T3 externally gated manifold. I want to get those plus a engine rebuild kit like bearings, water pump, oil pump, timing belt… Trying to do this with $1500.
Thanks for ANY help that your willing to share...
boost_boy
Well bro, $1500 won't quite cut it. And what's wrong with your CA that you need to bore it out?
Dee
Phixius
Don't know if theres anything wrong with the CA, Its still on a boat from Japan... Reason for overbore; I would like to get a little more TQ out of it (more displacment more TQ or no?) the Manifold is my biggest concern right now. Know where I can get one?
boost_boy
Why bother a perfect bore? Just boost the hell out of it. And if you want to go to a CA19, you may as well go for a CA20. If you're looking for 300-350hp, the stock CA18DET will accomodate you. If you want torque, you may want to be looking at boosting your KA.
Dee
Phixius
LOL, im done with the KA, nuff said.
OK, youve convinced me, stock bore. Anyways....Manifold? lol
boost_boy
If you're going to be using a T3 or better and want a manifold, you need to determine what kind of wastegate you want to use. If you want one done soon, i can possibly assist you because i'm having a few made which includes one for a fellow board member. Let me know, but do it soon.
Dee
Phixius
I will be using a 38MM Tial wastegate...
If possible could you E-mail me with more information on the manifolds. Clearance issues, price, what ever.... [email protected]
boost_boy
I'll drop you an email in a minute. nab911's manifold is also using a Tial wastegate in which he gave me a flange to make the dump.
Dee
littlemilla3
boost_boy wrote:Why bother a perfect bore? Just boost the hell out of it. And if you want to go to a CA19, you may as well go for a CA20. If you're looking for 300-350hp, the stock CA18DET will accomodate you. If you want torque, you may want to be looking at boosting your KA.
Dee
Can you bore more than 84mm, or is this the max before interfering w/ water passages?
biosehnsucht
Some of the crazies on http://www.sxoc.com (european forum) have done 84.5 I think... I'm only planning on 84 myself tho, but with 9.5:1 pistons..
CA19DET
i got JE pistons from TopEndPerformance.com i think i *may* have the part numbers on file. they were on the box they came in and that all went by my friends garage.
but i KNOW JE has them on file so you can just call em up and ask for it, and then go through a distributor.
when i had ordered mine i got some psecs for the JUN super pistons for the CA (gods knows where from now) and i sent it to Steve at TopEnd and he passed it onto JE. so hopefully they will be using some of the specs.
