Need to change Tie Rod Boots/Bushings
oxs1
I need some info on how to change my tie rod boots/bushings as well as my steering rack boots. Are these ez diy jobs if not what are the estimated labor charges involved. I think the boots might be the ez part.Thanks In Advance
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
About equivalent in difficulty and easier to do together. The only hook is you'll need an alignment after you finish. Don't wait to replace the steering boots cracked boots=dirt=failed seals in the expensive and tough to swap steering rack.
