Need to change my headgasket have a few questions.
ORICLE
Car: 1992 Nissan 300ZX, 1989 Nissan 240sx (sr20det), 1990 Nissan 240sx (future home of the other SR20det)
Sorry to bother everyone I'm new to the SR community. I have been looking for DIY on changing my headgasket. I have a redtop in a s13 hatch. I found the head removal post in the tech page which is great. My issues are that I'm chaning the headgasket with the motor in the car. I'm not that experienced with cars but I also dont have the money to pay for labor so I'm trying to do my own work. Plus I really enjoy learning along the way. The issue I'm running into currently is the intake manifold. I've searched and all I pull up are KA intake manifold removal ?s. I'm trying to find out if I have to remove the upper and lower intake as one or can I remove just the upper manifold. I was hoping to find a write up on what all I need to remove for the headgasket swap. Since the writeup on the tech page is with the motor out with the manifold already off and free of everything I'm kind of lost. Any help would be great. Thanks.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
FSM is your best friend. I always take the intake off in 1 peace. I remove the 2 braces, un-bolt it from the head, pull it away from the head and remove the vac and coolant hose's. Then it comes off. remove the turbo mani, valve cover, timing chain tension-er, CAS, cam's, head bolts and then the head comes off. If you remove the lifter's, rocker's, valve shim's and retainers, put them in the same order they came out. Again, you should download a fsm.
http://www.primera-egt.com/FSM...0.pdf
Kalypso
SR manifold removal by assassin7420
ORICLE
Thanks alot I appreciate the help. I pulled the head yesterday and a friends is helping me lap the valves and refresh the head. I just purchased a new intake manifold and exhaust manifold so I'm debating picking up a t28 and some other toys. Thanks again.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Make sure to have the head checked and resurfaced before putting it all back in. At least that's what I'd suggest since you already have the head off and you're putting on a new head gasket.
ORICLE
Sounds good I appreciate it.
nzmoman
Car: 240sx 2 of em' and always lookin for more
Also you should consider replacing the head bolts as used ones tend to have some stretch in them, you won't that when reinstalling a head. You don't have to do it, but its one of those since you are already doing the work then you might as well.
ORICLE
thanks I have new arp studs I ordered with the head gasket. good to know.
