There is a very horrible vibration and grinding noise in my transmission and Ive replaced my driveshaft to a one-peice, new diff and axles, now i just dont want to bother with it anymore and i want the noise to go away. The vibration comes up through the shifter and is the worse at 3k rpm on accel and 3200 down to 2200 on deaccel in any gear accept 1st. If lifted the car up on the ground and listened throughout to see if it was coming through the rear-end up into the shifter, but ive done everything i could and its limited it down to the transmission. I guess it could be one of the berings on one of the two shafts, but my nerves are done with this so... I would like to buy a 5speed around the same miles on the car about 91k, the car is a 93 S13. If you know what this problem could be or have a good cond. transmission (no clutch or flywheel needed) from a KA24DE left over from an SR swap or somthing plz contact me asap at 702-686-2073 after 12pm or just email me at [email protected]. I need it for the justdrift event Feb. 26 Thx
-Josh
