skydragoness5 wrote:Kumho Ecsta Supra 712's i think they are performance wet/dry only. but i have heard nothing but the best about them, for multi-use tires. they wear hard, have excellent grip, etc. i am getting them as soon as i get a set of 16" rimsand i'll be keeping my dunlop sp5k's for the winter
Nismo_Freak wrote:LOL!!!!!!! ... Ecsta Supras have great grip ... this tells me one of several things:
1. You run 15+ sec. times at the track2. You have stockish suspension3. You dont drive hard enough4. You havent used anything else nor have your friends
Alot of my friends made the mistake of using Kumhos... they are crap.
My friend's Subaru 2.5RS nearly got toasted when a tire blew out totally on it own. This is on a cold day, no performance driving.
My friends 240 gets absolutely no traction in 1st or most of 2nd with his SR. Stock turbo, runs high 13s.
Upon a run at the local twisty road from hell the tires fatigued incredibly fast to the point they became questionable.
Also at this trip the tires sucked horribly at grip driving so we had to resort to driving sideways... in an AWD car setup for grip.
skydragoness5 wrote:I suppose the things i've heard about Kumho's were all wrong NismoFreak:
http://www.tirerack.com/survey...Y.jsp
there are a lot of factors that can be considered into why a tire woud fail catastrophically (for it happens rarely) and i don't believe they are designed for drag racing. this is a wet/dry performance tire.
i'm not exactly sure what kind of Yokohama's my ex has on his 5th gen 'Lude, but i've watched him cut down his autocross times when he replaced his p.o.s. bridgestone's with them-- they are also all-season performance. and do decent in the snow (so he tells me) , very pricey though. they stick even better now with the use of a sway bar. time will tell in how long they last.
i am swayed towards the kumho's because they are reasonable, wear hard, and will probably make a good autocrossing tire. if don't get these i'll probably get the yokohama's that i've mentioned above or i will go with a different kind of dunlop.
95silviase wrote:Yokohama AVS ES100's rule. I think thats what they are.
b240 wrote:I just got my set of Yokohamas AVS e100s as well a couple weeks ago.
