Q451990 wrote:After doing some research I've narrowed it down to a few different tires, all in the 225/55/16 size:
Pilot HX MXM4Load Rating:99H or 94VPrice: $157.00 for 99H or $151 for 94V
Pilot Exalto A/SLoad Rating:95HPrice: $125.00
Energy MXV4+Load Rating 95HPrice: $132.00
I have used the MXM4, albeit not on a Q. It is a bit over-rated and over-price, IMO. There are better tires out there. I have also used the MXV4 tire and was pretty dissatisfied with its performance and handling. Bottom line: both tires were quiet and reasonably long-lasting, but mediocre.
So, since you mentioned that you only want Michelin, the Pilot Sport A/S is a better tire than the ones you list above. A bit more pricey at $181 a whack though.
If you are willing to try other brands, the Goodyear Eagle F1 GS-D3 is a much better tire than any of the above Michelin models. And it is reasonably priced at $140 a tire for the 225/55-16 size.
It will not last as long as the Grand Touring tires you have picked, but it will be far stickier and better handling/braking in wet weather.
Finally, if you live/travel much in snow country, then you should also consider some cheap steel wheels with good snow tires - using all-seasons is not really a good enough alternative.
Z
