Need tire help ASAP!!!
mrgrape
Car: s14
Okay so i have a 17x9+35 rim and i normally run USED 225/45/17
One day I came up on a pretty new looking 225/45/17 so i tried getting it mounted and it was too big....
I realized because there was a lot of tread left compared to the other worn out used tires, that was why I couldnt mount it on the front....
Anyways the car has been running pretty s*** lately and i noticed the inner tires on the front were worn up-my fault as i run used tires...
I decided to actually order new tires for the front and bought some s-drive 225/35/17......
When it came in this morning, I realized it was rather slow....and I should of went at least with 225/40/17....
Now I am wondering, can i run a 225.35/17 on a 17x9+35 with +25mm spacers???
Please help as I need to get my car running before school starts!
thanks
costa_rican13
Car: 1993 s13 coupe
technically you run any size tire the rim will let you. lol it all depends if you're trying to be hella flush :yesnod or on a budget. :eek:
240lookis
Car: 1990 240sx hatch
yes that will be fine. however, that was a stupid tire size to buy because it will have a much smaller overall diameter than the stock wheels/tires, therefore your speedo will be off.
kouki munster
Car: 97 base 240
240lookis wrote:yes that will be fine. however, that was a stupid tire size to buy because it will have a much smaller overall diameter than the stock wheels/tires, therefore your speedo will be off.
He is putting them on the front.
