USDM240 »
https://forums.nicoclub.com/usdm240-u14667.html
Fri Aug 03, 2007 9:00 am
that will allow you to drop the steering column down and away from the cluster and also let you remove the plastic trim panels with out breaking them, or cracking them. ive actually removed the cluster without dropping the column and let me tell you: it is a PITA! luckily i didnt break anything.
to install that cluster, you will either have to cut a hole in your existing dash, or purchase a HUD dash and swap them out. i personally would swap dashes. the hole is already in the HUD dash, whereas if you mess up your current dash, you will have to purchase another one anyways and be out the money you could have made by selling your old stock dash. make sense?
as far as the cluster install, it shouldnt take you more than 30 mins. its just plug and play.
hope that helped some. :
