squonk »
https://forums.nicoclub.com/squonk-u91456.html
Thu Jan 29, 2009 12:06 am
I had a similar circumstance minus the whole melting part... In my case a fuse was blown and power would only turn on after I touched the gas. So start the car, nothing will work not stereo or anything hit the gas see what turns on *in park* now every time you drive and hit the brake you should notice that **** will turn back off.. If this is your problem on top of the melting issue, go under your hood and check fuses. Goodluck!
