Maybe I am retarded and missing something here...biosehnsucht wrote:You need an injector resistor pack, regardless.
If you have one (stock or DSM) then you don't need another, doesn't matter which you have. You can use DSM injectors w/o anything else, excepting of course a ROM tune or a SAFC type device to tune the ECU for the injectors.
I already have a S-AFC and the 550cc injectors. I will be using that in conjunction with a Z32 MAF. I would prefer to get a base rom tune for the 550s and MAF and just use the SAFC to fine tune it on the dyno.biosehnsucht wrote:DSM is physically and electrically a direct replacement but you WILL need some way to control the injectors as you would run uselessly rich with a stock ECU. Either tuned ROM on the ECU or a SAFC or similar device
Umm...yes, I know. But I had 550s in my eclipse before I put it back to stock. I was running an EVOIII 16G, 550s and a SAFC.RMiller wrote:DSM injectors are 450cc.
Sorry, I didn't mean to sound condescending. Sweet setup you had on your DSM. Evo 16g is so awesome.c-rad wrote:
amen to that...i actually did write them about dsm turbo's as i am just getting out of that scene also...we'll see what they say (if they reply)c-rad wrote: I REFUSE to take my car to the shop for anything other than alignment and tire mounting/balancing.
CA18 and 4G63 engine designs are VERY similar. I just put Nissan a few pegs higher than Mitsu in terms of build quality. Plus everyone and their brother has a DSM. And let us not forget, fwd = teh suck.float_6969 wrote:It's funny to me how many DSM'ers we get in here....
Only the 2G 7-bolt motors got crankwalk. And at that, it was still a rarity. I got crankwalk on mine, so I replaced it with a 1G 6-bolt motor. I've never seen a 2.4L stroker...only a 2.3L. You CAN use the 4G64 which is a 2.4L engine that comes in the spyder models and various older hyundais.T88lexus wrote:there is a different than 4g63 than ca18det..
4g63= crank walk, weak transmission ( later model of evo are better, freind here has RHD evo5, his hold up pretty well)ca18det= no crank walk, but weak transmission( I dont call any sr,ca,ka transmission strong) unless they are RB25,or VG.
I worked on 4g63 with 2.4 stroker with T61 and 75 shot. who know how many motor he wen thru.. just because of CW.
but only thing about DSM.. they could be wack up fast if they decide to run
I know I'm bringing this back from the dead, but this is a really good idea. I know a pretty god fabricator...c-rad wrote:Yeah, if I could get a manifold with a mitsu flange I would just put that turbo on the car. I got that turbo brand new with gaskets and new crush washers for $569 shipped. Maybe we can convince forced performance to make a T25 style housing to fit the TD05 turbine wheels. That would open up the options for the 14b,16g, 18g, and 20g (TD05 version 20g anyway...)
You do know 4G63's have rockers right....Mitsu likes hydraulic lifters and roller rockersc-rad wrote:....cams acting directly on the valves...
