nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Mon Jul 05, 2004 11:25 am
Turn on the pump and shove the pole up and down (don't that sound great?) to prime the pump. After a while (could take quite a while, actually) the pump will start sucking shiat out, and assuming you turned the valve to the pump to waste setting, you're clear!
<- Lifeguard, aka pool *****.
