Braided teflon brake lines can improve pedal feel and reduce line expansion which causes pressure loss. Our custom built brake lines from Technafit feature a smooth bore inner teflon hose, bonded stainless steel braid reinforcement, and an outer cover to prevent dirt from getting between the steel braid (which can rub against the teflon hose and over time cause a rupture).
We have many of them in stock and ready to be shipped out.
If you are looking for Z32 conversion lines please be sure to mention you need the conversion lines. Our conversion lines have the correct flare fitting to insure proper fitment with Z32 calipers. Our S14 conversion lines even are custom developed with a shallower angle on the flare fitting to provide better fitment.
If you have factory brakes and are looking to replace the lines then please select the banjo fitting lines.
In any combo the brake lines are $88 shipped!
Questions/Comments/Orders please email me:
[email protected]
