Need SR20DET Doctor
driftking91
Car: 1991 240sx
OK first problem 1) Brake, seatbelt... red lights on dash wont turn off after i close the key. 2) Fuel pump will only prime one time after i connect battery, but will not prime there after. 3 Car refuses to start, it comes close, but wont. Im wondering if it has anything to do with problems 1 and 2 all fuses check out and wiring harness is brand new and proffesionally done. I tried the J4 ECU and the new Chipped ECU. I already read over the FSM and it was no help. I did a search and tried a couple of things, but the SR wont take that last crank just alot of cranking no turn over.
MY SET UP1991 240sx Fastbackw/1997 180sx type-x blacktop sr20dets15 T28 TurboDeatchwerks 555cc Injectors#80 Nissan tuned ECUGreddy Cold Air Suction KitGreddy FMICGreddy Turbo TimerGreddy Boost ControllerGreddy Type RS Blow off ValveAlluminum RadiatorRacing stainless steel ManifoldTop Speed Exhaust from Turbo elbow, Down pipe High flow Cat and Catback 18x8.5 and 18x9.5 Sportmax 962 WheelsTein Lowering Springs
CoupedUp
Car: 1993 Coupe
A friend of mines lights did the same....even after he removed the key. He removed the Eng Cont fuse and that stopped.
Fuel Lines reversed?
Professional wiring can be wrong. Yuri kind of messed up a friends RB25 harness. Was wierd.
