Changing Springs what else to do whiles im at it!?
Wkz1gg0a
Car: 99.5 Nissan Pathfinder SE limited edition
I need new springs badly my Pathfinder sits about .5in lower then normal R50's i see and the annoying thump sucks when it bottoms out. i know i got about a 2year old KYB rear shock on both sides. I dont think my front struts where ever replaced. I cant find a source where to buy 4 coil springs for my R50 any suggestions? I found the Struts and Shocks on Autopartswarehouse.com and is there anything i should replace whiles im at it? Thanks in advance
Wkz1gg0a
Also ive heard excellent things about KYB is their any other brands recommended
Ron Burgundy
Car: 1999.5 Nissan Pathfinder 3.3 LE
Front
Struts
Misc. Strut Hardware
Dust Boot/Bump Stop
Front Stabilizer (Sway) Bar Links
Rear
Rear Stabilizer (Sway) Bar Links
Bump Stops
Shocks (Nuts/Bolts)
I've heard nothing but good things about most KYB and Rancho products. I've also heard Blistein (sp?) shocks are good.
Dealership (Stock)
http://www.courtesyparts.com/pathfinder ... _4701.html
Aftermarket (Slight Lift)
https://www.4x4parts.com/nissan/suspens ... 5_436.html
http://www.rocky-road.com/pathfindersus.html
http://ruggedrocksoffroad.com/pathfinde ... 8_593.html
I'm sure a google search would return more sources for stock coil springs.
Wkz1gg0a
Thanks for the reply i will do another google search
Wkz1gg0a
Wkz1gg0a
Wkz1gg0a
donald
Car: 2001 Infiniti QX4 (RIP, 2011)
2010 Pathfinder LE
what is the effectivness of the dust-boots?
Of all the cars I've seen (except new) the dust boots are always torn at some point, thus exposing a part of the strut-shaft. So, I'm wondering if this is strongly suggested? or just a peace-at-mind sort of deal?
Thanks!
Ron Burgundy wrote:Front
Struts
<<< Dust Boot/Bump Stop >>>
Rear
Bump Stops
Shocks (Nuts/Bolts)
Dealership (Stock)
devonianwalk
Car: 99.5 Pathfinder LE 3.3
I just replaced all four coils with AC 2" lift springs. While there, I replaced the factory struts with the KYB's and the rear with Rancho shocks. So far, so good. While messing with the struts I replaced the strut bearings and the strut mounts with Nissan factory parts as I heard that the KYB's were s***.
shelby500krz
Car: 2001 Nissan Pathfinder LE 2WD
From what I have been told it seems to be a piece of mind thing. I was told that if you ever go in sand or dirt then then the boots have a tendency to get dirt and sand trapped inside of the boot and screws up the strut or shock.
donald
2010 Pathfinder LE
haha, great!
I live nice-n-flat California...
I don't really have any plans to go off-roading, so maybe I should not have purchased my dustboots and just use the old ones.
I'm sure the bump-stop on those old ones are still resuable.
Pathofinder
Car: 2001 Nissan Pathfinder 2wd Vq35De
devonianwalk wrote: While messing with the struts I replaced the strut bearings and the strut mounts with Nissan factory parts as I heard that the KYB's were s***.
Ive heard these parts need to be replaced when dong a front end overhaul aswell
Do you happen to have a part numbers for the mount and bearing?
