Need Spring Rate Info on Tein Basic and Nismo S-Tune
rico05
Car: 1992 RMS13 w/ CA18DET
What are the spring rates of these two setups? Tein Basic damper and Nismo S-Tune.
rico05
Ok, to the top it is
Ceptos
Car: 95 240sx
http://www.japanparts.com
check out their suspension section for info on nismo components.
it looks like tein basic dampers for an s13 have 6kg front and rear. you might want to double check this....found both on google.
LiU
Car: Cars
tein basic for s14 is 6 kg/mm front and 6kg/mm rear, this lady at http://www.performancenissanparts.com or somn like that toldme the nismo s-tune are 5.2 kg/mm front and 4.5 kg/mm rear for s14s.http://www.tein.com has more info on the teins. I too am conparing between basic dampers and stune coilovers.
rico05
Wow. Def. looks like the Nismo is a true comfort coilover! Looks like this info shows that I am going to be getting Tein basic coilovers as oppsosed to any of the other setups I was looking at.
LiU
Car: Cars
yup I probably will get the tein basics also... enjuku said that teinonly alottedthem 1 set oftein coilovers, hopefully they'll get more in the future.
Ceptos
Car: 95 240sx
the difference in spring rate ratio front to rear should be considered. tein basic keep stock, nismo are somewhere in between that and what most other coilovers use (the 8/6).
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
where are you gonna get these teins from?
rico05
I found an eBay seller who sells em for $780 buy it now shipped. If he runs out before I can get em, then here:http://www.digitalracer.com/ca...id=44
