Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Sat Jul 05, 2003 8:34 pm
unless this is just a quick fix, i would take a little time to either pick a coilover and customize it to your needs, or match a set of nice springs and shocks together. (eibach will custom rate springs, right?) maybe ask around, or at some level research the actual spring rate your application will need. it sounds like you will be competing at some level if you need an aggressive rate, springs and shocks are crucial to the suspension system, so why not get something quality, that will perform and last. if you spend a little more money now, u may never have to spend it again on that same part.
