I also have a huge mess of plugs int he engine bay, but i'll need pics of those.
....well, are you sure it's plugged in on the other end? maybe it's orphaned from the KA?ToplessVert wrote:Its not a consult port. A consult port is almost half that size. I have a consult reader to compare the size, as well as a 96 Sentra and the odb2 port is a trapazoid shape. Also a SR20DET redtop isnt wired for a Consult port.
Is the cruise cancel switch plugged in on the brake pedal? It should be a blue male plug, and if you swapped your brake pedal for the skinny 5 speed brake pedal, it's possible the one you got wasn't equipped for cruise while the clutch might have been. The wire colors for that plug are Green/Red and Green/Black.ToplessVert wrote:clutch and break pedal are both pluged in
