Have fun replacing studs and gaskets with the 2 piece. None of them have a proper flex joint with ground clearance. But it looks like your set on a 2 piece, so why make the thread if your mind is already set?OM3GA wrote:Yeah ive seen all those pics of that one. It is nice for sure and the clearance is great however i still like the idea of a two piece design
I'd love to post pics, but I'm quite a bit aways from home right now. I'll try to get someone to take pics then I'll post them up.OM3GA wrote:I'm trying to see how low two piece ones actually hang since i havent seen any pictures out there. This thread is strictly comparison and to see how others go about their lives with their elbow/downpipe setup.
You should ALWAYS run a flex section on a turbo car, moreso when you have an aftermarket manifold. Things like to crack with no flex section. Either way if you run the trans hanger or not the PBM will have a lot more clearance than anything else. Also helps to hose clamp your rubber hangers up. That wil pull the exhaust up a good bit.OM3GA wrote:I'm trying to see how low two piece ones actually hang since i havent seen any pictures out there. This thread is strictly comparison and to see how others go about their lives with their elbow/downpipe setup.
The PBM piece is amazing definitely, my mind is not set that is why this thread exists.
I know none of the two piece ones have a proper flex section but given enough ground clearance they may not need it, I havent scraped my exhaust system before but it was 2.5" and parallel with the frame rails im just hoping that can be achieved again with 3"
One thing about the PBM pipe which i cant use is the transmission mount bracket. I run a peak performance transmission mount which does not have the stock bracket attachment so i am worried that the PBM pipe would sag in that spot making the clearance worse than a two piece setup.
Yes that is true i believe the same thing about running a flex section if there is ANY chance that you may bottom. I have heard of the hose clamping the hangers also however i run polyurethane hangers so i think those do the trick already.LayNLow240 wrote:You should ALWAYS run a flex section on a turbo car, moreso when you have an aftermarket manifold. Things like to crack with no flex section. Either way if you run the trans hanger or not the PBM will have a lot more clearance than anything else. Also helps to hose clamp your rubber hangers up. That wil pull the exhaust up a good bit.
