Brent.S13 »
https://forums.nicoclub.com/brent-s13-u160629.html
Sun Dec 12, 2010 7:51 pm
Yeah, if you're gonna replace the water pump, I'd replace the t-stat as well, because there's no tellin' how long it's been since it's been changed, if at all. If belts are worn and are slick, replace them, no use in putting on old belts that are going to fail on you. Bleed the system if needed, which is most likely going to be needed. Seeing as it's cold as all get out outside use antifreeze, NOT water. That's just asking for trouble right there. -.- It's a real easy process to do man, just takes a little bit of your time. Good luck!
