duffman1278 »
https://forums.nicoclub.com/duffman1278-u61344.html
Tue Dec 04, 2007 11:34 pm
Take out you spark plugs, make sure there's no fuel on them, or in the cyclinders.
Also, as for checking the spark, I would suggest getting a spark plug tester thing. I think you hook it up to the spark plug, and if it sparks than the thing will light up, so just crank hook it up yourself and see if it lights up when you crank.
As for checking the ignitor, your going to need someone for that, because you should have someone crank it while you hook it up to a multimeter and check for voltage.
