sstomek »
https://forums.nicoclub.com/sstomek-u31323.html
Sun Apr 15, 2007 11:05 am
yea after a day of sitting when i sprayed it with pb we were finally able to get it off after a little bit of wiggling however a good way of taking it off without actually damaging the tube would be using a heat heat gun to expand the rubber a bit and than taking some pliers and putting it right above the hose (not on it) and give it a firm clamp and use a hammer to tap on the top of the pliers and it will start to slide off. than if that doesnt work you can start bringing in the chemicals but you have to be careful with chemicals
-Tomek
