Need some swap info
Sildrift80
Car: 240sx (stock at the moment)
anyone know of all the parts needed to do the SR swap without buying a front clip.. Its just too expensive for me thats why i dont want to buy front clips. Also what would be the best aftermarket driveshaft that i can find and where i can find it.. thanks
DriftBandit
Car: this is my 3rd 240sx
Theres tons of info on what parts are needed to get an sr running without a clip, you just got to search a little. And if you are on a budget why are you looking to buy an aftermarket driveshaft which will run you around $450.00(http://www.store.yahoo.com/phase2motors ... dr8924.htm)
msaskin
Car: cars, computers, skiing, mountain biking
Motorset:-motor-ECU-wiring harness-igniter chip-coil packs x 4-MAF-accessories (both manifolds, turbo, alternator, p/s pump, a/c compressor, starter, etc...)
Other stuff:-downpipe (stock or aftermarket, doesn't matter)-fluids-belts-intercooler (stock sidemount would come w/ a clip, otherwise you need to buy a stock sidemount or aftermarket front mount)-hotpipe/BOV (if you get an aftermarket front mount you'll need to get a separate hotpipe and BOV setup)
That's about it.
Buying a clip is a complete waste of money. You're better of just buying a motorset from a reliable source and getting the other parts yourself. I still have never understood why people buy clips. Every swap I've done (at least 6-8 at this point) have all been done from motorsets.
~matt
