Need some s14 SE radio help...from a genius.....
Post all your Nissan electronics, car audio and stereo questions here!
nzmoman
Car: 240sx 2 of em' and always lookin for more
I had my car stolen on New Years Eve, and I got it back. the theives stole the radio, but they cut the entire harness out from the dash harness. Since then, I purchased the harness connectors and pigtails, but I have no idea, what goes where. I got the wiring guide for the SE chassis, but the plugs I have and the wires from the harness do not match up. Check out the pics. The plugs and the dash harness are for a 97 SE Anyone who can tell me which wires from the plug connect to which wires from the harness, that would be AMAZING!!!
the mess they left.the wires directly from the dash harnessalso from the dash harnessand colors from the dash harnessplugs wires up closethe plugs again
So I think you get the point. I want to get a radio installed soon but this is not working for me.
andromeda
what year is your car?
andromeda
actually i just read it, the plugs are for a 97. im retarded. http://www.the12volt.com/insta....html
that should help. 1995-97 Nissan 240 SX Stereo WiringConstant 12V+ Pink Switched 12V+ Blue Ground Gray Illumination Red/Blue Dimmer Red/Yellow Antenna Trigger Green/White Antenna Left Rear Front Speakers 6 1/2" DoorsLeft Front (+) Pink Left Front (-) Blue Right Front (+) White Right Front (-) Black Rear Speakers 6 1/2" Rear DeckLeft Rear (+) Light Green Left Rear (-) Purple Right Rear (+) Blue Right Rear (-) Pink
nzmoman
thanks a ton.
are you telling me the wires from the plug or the ones coming off the harness. The issue I have is that the wires off of the plug only match the harness with about 4 or 5. I am clueless as to how that is supposed to work.
Note:-in the pics the chassis wiring has several brown wires that are not on the plugs,-the same goes for the wires on the plug that are there but do not exist on the harness. is there another pig tail that im missing? I dont see this type of transition on my 95, but its a base model?
andromeda
hmm. ya wiring is always confusing haha. it looks like at least the power wires will match up to the diagram i gave you. if thats the case i think you could possibly figure out the speakers by elimination. like set the stereo so its fading to the front left and then try the wires til that speaker comes on, then fade it to front right, ect.. (theres probably an easier way hah, im not the guru you need!) anyways hope i helped you a little bro
P_856
Car: s13
im almost positive the bundle with the most wires are for the radio and the other ones are for the HVAC (AC HEAT) control
nzmoman
the HVAC controls are all still there and working fine.
thanks for the help guys. I will just get a radio and figure it all out.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I'm assuming that this car had the factory amplifier in it at one point. The leads going to it are going to be a different color than what everyone lists. You should have 4 pairs of wires that are twisted together for your speakers. You can either take a 9volt and pop out what speakers are what or I'll dig around and see if I can find you the wiring.
nzmoman
The car did have the factory amplifier. It was stolen when the previous owner had it and he replaced it with an $800 MP3/Ipod player, and amp. He also replaced the speakers.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
alright here we go
fl+ Blue/whitefl- Blue/yellowfr+ Brownfr- Brown/whiterl+ BLuerl- Pinkrr+ Redrr- Green
nzmoman
thanks...im gonna give this a shot tonight or tomorrow.
