need some quick help
zache803
Car: Ca18det powered 240sx
ok this may sound stupid but ive never owned a turboed car before so bare with me please(ive already used the search option and nothing came up) wat all does it take to use the hks ssqv on aftermarket intercooler? dont rag on me too much
superJoy
Car: 1989 RS13
Buy a flange that's same material as the pipe it's going on (aluminum or steel), get it welded on, stick the SSQV in the flange, hook up vacuum line... you'll have to decide whether you want it on the hot or cold side, either works... hot side is easier to recirculate which may be necessary if you're using the stock engine management and you don't want the engine to run rich and stumble when the valve vents
http://www.frsport.com sells the flanges, they're a forum sponsor
zache803
ok thanks alot
