bruinbear714 wrote:0.9 bar = 13psi.
That is what I wanted to hear. My next question is at 19psi with the new rad cap (which seems to be WAY higher), which my new cap was, that would be enough to cause blow by guys? I mean I know this is a flow system not a pressure system by nature, so I assume adding almost 50% more pressure you would guess it would cause blow by, is that an accurate assessment? Does anyone have experience in this?
Could I reduce the PSI at the cap down even, to maybe 11 to 10psi in the cap?
Like I said this seems to be the issue in the back pressure on my new seal, I will put my old cap on to test but it is old, going to the zone or pep to get a cap soon because the rubber part of the cap is not very good. I would like to maybe take more pressure off the system just a little.
Ideas? Disagreements?
