dana541 »
https://forums.nicoclub.com/dana541-u136397.html
Wed Mar 03, 2010 4:51 pm
Well i did i good deal of searching before posting this but couldnt find much due to my possible problem being a different from normal timing chain rattle.
so here is the deal.I did a full rebuild on my single slammer ka back in may(im a diesel tech so i know my way around under the hood)I replaced pretty much everything including the timing chain tensioner,chain and guide.so lately i have been noticing a rattle on cold startup, so i finaly pulled the valve cover and did a little inspecting.what i found was my timing chain slightly slipped over the backside of plastic tensioner(not much just the first part of the connecting links).i also noticed that the plastic tensioner arm is not centered on the tensioner pin.i can actually move the plastic tensioner side to side a bit with a screwdriver.Either one of two things are going on1.the pivot bolt that holds the plastic tensioner to the engine block has rattled loose and backed out causing the timing chain tensioner to have enough side to side play to not be straight against the chain or the tensioner pin.2.the timming chain tensioner is a total cheap pile of crap and it has some side to side play
what i have not determined is if its moving side to side from the actual pivot point (way down where i cant see) or im just moving the top part of the tensioner because it has some flex and its very long.
any opinions would be a great help on this none centered timing chain tensioner situation.just trying to save my self the trouble of pulling the front engine cover just to check one bolt and find out that its tight.
Thanks
