phatsentra96 »
https://forums.nicoclub.com/phatsentra96-u141837.html
Sun Sep 06, 2009 6:45 pm
I'm turning the 240sx i got few weeks back into a drag strip car. Taking alot of work but thought that I had everything fixed and took care of but evidently not.Got a few questions for those experienced that could help me out. Please be gentle, I understand engines and whatnot but I'm not a transmission guy or completely understand every little thing about the car yet, I'm still on a steep learning curve.
1) When you turn the car to ON, not starting it, you can hear something under the hood like a relay or a wire shorting out about 4-5 clicks and it stops. It's not my fuel pump, thats working normal. No fuses are blown or anything traceable. Maybe a short who knows, clock has been acting very funny lately and not sure why if it means anything.
2) Also when you turn the car to on but not starting it my speedometer has gone completely ballistic and pegs out. Sometimes it resets and works, other time it reads whatever it wants. If its only in the speedometer and rest of the car is fine not a problem.
--Followed the procedures in the FSM for the A/T CU and only issue I had was the fact that the OD light was burned out, and I kept getting the battery code since I had just hooked the battery back up to it. Its on jacks atm, trying to figure out why my right rear brake is going blue so its not driveable at the moment.
I went ahead and pulled out my VSS and tested it since it was a simple thing to do. Barely turning the VSS it was reading about .1 volt and turning it very fast by hand it would read around .7 volts. Is it supposed to read .5 volts all the time or is mine bad? Would make sense if it was because at normal driving rpm's the car shifts mostly fine, but at WOT it will not shift at all unless you get out of the throttle completely.
By the way, in stock form, minus have anything interior removed from the driver seats back, should I be spinning the tires in D when I leave off the line? It seems like there spinning almost to the 60ft mark unless I feather the throttle to control it. Reason I'm asking is the fact that a few things was out of place, but I have not seen a almost 200k engine be this peppy and responsive, considering the fact that when the transmission refused to shift on me a couple times, she pegged 7k on the tach a few times and nothing has let go or any engine damage that I could find without taking it all apart. Kinda surprised there wasn't a rev limiter keeping the rpm's down, granted it never stayed at 7k for more than maybe a 1/4 of a second if that.
