need some of your knowledge
streetbikestunta420
Car: nissan 240sx/red top sr20det
ok so my upper oil pan is leaking oil..badly , and im pretty sure its cracked (hit something pretty hard)i looked on ebay but was not able to find one. where can i buy one (for cheap) ..also do i need to raise engine for this? what would be the best way? its a retop sr
also while at it i wanted to buy a bigger capacity oil pan, i found the greddy one (400 bucks), and some knock off ones on ebay that look similar design ( 120 bucks) ...should i save up for the greddy one or would the knock off be just as good (well im pretty sure the greddy one is way stronger and higher qualily , u get what u pay for) but sadly i have no money and broke this month (stupid christmas) and i need my car running now. do you think the cheaper one will crack too easy? or should i just get JDM from nissan and save for the greddy/other known brand?
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
You could try having it welded, probably a 50% chance it will weld up depending on how clean you can get i,(cast soaks up oil).
streetbikestunta420
true not a bad ideanow whats your opinion on the oil pan issue?
Thoughtful_One
Car: 1998 Nissan 240SX SE
2000 Honda Insight
Look around on Nico and Zilvia to find guys who blew their engines and are parting them out. That's your best bet.
boro drift
streetbikestunta420 wrote:whats your opinion on the oil pan issue?
Post a link to the e-bay pan and I'll look at it.
streetbikestunta420
boro drift wrote:Post a link to the e-bay pan and I'll look at it.
pretty much any of theses..any1 have expiriance wit them?
http://shop.ebay.com/?_from=R4...ories
Justin35ll
Car: s13 coupe sr20det
They look pretty nice, I did hear one time that the ebay knockoff was hitting the front sway bar. Can't remember if it was on an s13 or 14 though
boro drift
http://cgi.ebay.com/ebaymotors...ories
The casting looked better on this one, no pits or voids like you can see in the other pan.
